Auto RX Question
I've used AutoRX on 4 vehicles. On the Jeep and my 300Z it made no significant improvement-but I didn't expect it to. It was more for preventative maintenance.
On 2 other vehicles it made a big difference.
8N Tractor and Nissan Sentra
Both engines saw a big benefit from the AutoRX treatment. Granted-I didn't take the engines apart for before/after pictures. However the compression test on the tractor showed that something sure cleaned things up-most likely rings and valves. The only change other than the tune up was the AutoRX treatment.
LVHospiceRN,
Here is more photos of satisfied Auto-Rx user.
I have been using Auto-Rx in the van for 2 years. Auto-Rx has stopped an oil leak during this time and I was curious to see for myself just how clean the engine was so I had decided
to pull the valve cover. I was not all that surprised at just how clean the engine is considering that the Van has 185,000 miles on it because I knew what the product was capable of doing. The discoloration of the valves is not varnish or sludge it is just that the metal has turned a darker color.
http://www.gordonramseygraphics.com/pages/daryls_dodge_caravan.html
they was not UFOs. they was metallic weather balloons. isnt this what the military told ya when you reported them
I noticed a difference in my truck after putting ARX in it. granted it only has 37,000. will try it in my wifes malibu as she dont liek to get the oil changed. also has a few seal leaks. this wil be the real test for me.
I really wasnt trying to be flip I have seen some unique things in the sky but I look often with my telescope,,
But seriously the ARX really seems to work, quieted down a tickylifter in my pickup & smoothed out the idle also use it in my hot rod.
Michael,
I'm going to buy a bottle of ARX for my sister in law. And i don't expect her to see dramatic improvement, but it's like you said, "preventive maintenance."
I'm seeing dramatic improvement in my civic but only because my engine had some major sludge issues which i didn't know how to rememdy.
