Auto RX maintenance dose for extended drains
Stewartstown PA
I completed the full Auto Rx program at 60k miles on Honda Accord. Since then I have put a 3-4 ounce maintenance dose in the car, and have run extended oil drains about 13000 miles with group Group IV and Group V oils. Does the Auto Rx maintenance dose lose its effectiveness after some miles. Frank referred to 6000 miles as an extended oil drain on the website with Mobil 1 and I recall 7500 miles as the highest I have seen on the website. I understand auito rx runs better with petroleum or Group III synthetic oils, but will likely run Motul, Amsoil, Redline, and similar oils for extended drains. What is the highest limit for extended drains?
Auto Rx it is a wonderful natural product, which does do a great job, as empirical evidence suggests. The natural chemistry and low toxicity of Auto Rx distinguishes itself from those "shock treatment" cleaners. It’s ironic Auto Rx performs best with a petroleum solvent like substance, and uses much oil in the cleaning and rinse process with 25 k mile treatment intervals.
I asked a couple threads down and the answer came back with run Auto-RX maintenance dose in whatever OCI you want.
Auto-Rx in a maintenance program will perform with any synthetic oil and will keep performing as long as you keep the oil in your engine.
Auto-Rx in a full cleaning & rinsing mode needs a Group 3 Oil or a Walmart Super Tech non synthetic oil.
Same as right above for seal leaks-sludge- heavy oil burning.
