J jarmstrong Joined Sep 3, 2003 Messages 137 Location mass Jan 18, 2005 #1 how about using a very, very small amount mixed in the gas of a 2 stroke engine where the crank is lubed by the gas/oil mixture? such as a snowmobile?
W wileyE Joined Nov 18, 2004 Messages 1,965 Location Kitsap, WA Jan 18, 2005 #2 I've used MMO in the fuel in oil injected snowmobiles. Not sure what autorx is? or claims to do?
B Bio-T Joined May 27, 2002 Messages 5,335 Location London, AR Jan 18, 2005 #3 Don't use Auto-Rx in any 2-cycle engine, not in the fuel or injector oil. Only use Auto-Rx in 4 cycle engines, never in the fuel of anything. [ January 19, 2005, 01:57 AM: Message edited by: 59 Vetteman ]
T tom slick Joined May 26, 2003 Messages 10,062 Location Central Coast, Calif. Jan 18, 2005 #4 I'm sure LCD will chime in but Fuel Power is a better additive for 2 stroke gas. mix a little Lube Control in also and it might even run better!
M MONKEYMAN Joined Jun 24, 2004 Messages 2,937 Location St. Louis Jan 18, 2005 #5 If you go to the Auto-RX forum they post this message in bold letters: Note: Auto-Rx is not compatible with 2-stroke engines
M michaelc80 Joined Jun 22, 2004 Messages 1,778 Location Central Iowa Jan 18, 2005 #6 quote: Originally posted by wileyE: I've used MMO in the fuel in oil injected snowmobiles. Not sure what autorx is? or claims to do? Click to expand... Do a search on this forum and you'll find more than you ever wanted to know about AutoRX.
