Auto-RX a highmilage engine
Abingdon VA
Im just wondering if it would be worth Auto-RX would be worth doing to a engine that has 212K miles I wanna get the most out of the engine I can since I just spent over 400 bux in the fuel system. would this help it go longer
I have 150 psi compression in all four cyl.s and runs about 68 psi oil pressure cold so its in pretty good shape.
I was thinking about runnin auto rx with PYB 5w30 since its winter and after I do the rinse go back to Mobil 1 HM 10w30 like im running now
I auto-rxed my engine at 215k miles. I didn't measure before and after compression but it does feel like it has a little more pull when accelerating.
I would suggest taking your valve covers off and if you have some junk in the valvetrain I would check a product out called Schaeffer's Neutra.
