Hi,
I've an Opel Omega MV6 with the 4L30E transmission (it is also used in some BMWs). It was overhauled around 40.000km ago. It works perfectly, but when the coolant temperature is around 100°C for some time, the transmission starts to act strange. It stays in 1st until around 3.500rpm (even when accelerating gently) and then goes to 4th. This doesn't happen to often, only when the outside temperature is over 30°C and I've the AC on.
Why can this happen? I thought that maybe it is an electronic "safe mode" to try to cool the transmission down.
Could it be a fluid related problem? (wrong type, low quality oil or low level).
Thanks in advance
Thanks in advance
