I changed the oil last night in my wife's '10 Q7 TDI. The oil was Amsoil European Formula 5w30. It had 7,700 miles on it and was the blackest, most soot filled oil I've ever seen.( my '07 6.0L PSD isn't nearly as bad.) It felt sort of silky to the touch, very strange. I took a sample and will report back when I get the analysis. I know Audi says you can run 10K miles on these engines between oil changes, but I'm not getting a warm fuzzy feeling after only 7,700 miles. After a little research I decided to put Castrol EDGE Professional LL03 5W30 in this time. It seems that Castrol worked hand-in-hand with the engineers at VAG when they were developing the new TDI engines. The oil was formulated to overcome some issues specific to these engines. Or is could be that I've succumb to marketing fluff. The icing on the cake is that it is VAG approved and Amsoil isn't.
What say you?
What say you?
