Audi 2.0T Repair Photos
CA
Photos and information in this post are for entertainment value only.
2015 Audi A3 2.0T, 98K.
After a spark plug replacement (NGK) and walnut blast service for maintenance, the engine developed a cyl #4 misfire under heavy acceleration only. Clearing the misfire adaptives resolved the issue for a few hundred miles, but the misfire returned. Freeze frame data on my Autel was worthless. So, more diagnosis was needed:
Valvetrain picture. Oil was leaking into the spark plug tubes. Plus it was an opportunity to check for broken valve springs.
Compression Tests:
#1:
#2:
#3:
#4:
Leakdown Test:
#1:
#2:
#3:
#4:
Compression and leakdown tests were fine.
Since I was only given a Saturday to sort this out, in the interest of efficiency, I replaced the #4 injector (which meant removing the intake again), installed new Genuine VAG spark plugs and installed a new Genuine VAG oil separator. So far, the misfire has not returned after 500 miles. 🤞
New/old. Apparently you have to buy the 3-prong clip separately; it is not included with the new aftermarket Bosch injector.
Did reading any of those plug insulators help get there? (injector swap)
Nice job.
Nice work(y), walnut blasting does a great job at cleaning the valves. I know of one case where some one did it but the valves where not fully closed and the walnut stuff got inside the engine.
Compression Tests:
#1:
#2:
#3:
#4:
Leakdown Test:
#1:
#2:
#3:
#4:
New/old. Apparently you have to buy the 3-prong clip separately; it is not included with the new aftermarket Bosch injection
This is a very good writeup about the diagnosis and great photos. I enjoyed this. Thanks Critic
Nice job.
Nope, the plugs were fine. But I replaced them again anyway.
That would be a bad situation.
What do you mean by a “new Genuine VAG oil separator”? The PCV valve?
Yes, PCV.
Compression Tests:
#1:
#2:
#3:
#4:
Leakdown Test:
#1:
#2:
#3:
#4:
Ford does not include the clip either. It is on their super awesome One Time Use parts lists though that don't actually include all the parts needed.
