some lsd vendors including auburn specifically recommend to use “non-synthetic” gear oilMost people overtreat their LSD's and then wonder why they get stuck in the mud.
I would add only enough LS additive to get rid of any chirp or chatter.
Glad it worked out.Brought the diff lube to within a 1/4" of spilling out the fill hole. Drove the truck 5 miles to a parking lot and did several figure 8s with the windows down. Didn't hear any noises at all. Also did a burnout that left two 15-20ft rubber tracks. Then did some more figure 8s at varying radii and speeds. So, the diff appears to be working fine with just the additive in the gear lube. Just need to top it off.
Thanks to MolaKule for the advice.
I have yet to see a technical, tribological reason for this statement.some lsd vendors including auburn specifically recommend to use “non-synthetic” gear oil
any particular reasoning behind this?
Because they are stuck in the 1980's thinking that synthetic oil is bad.... bunch of fools!some lsd vendors including auburn specifically recommend to use “non-synthetic” gear oil
Would be nice to speak with an Auburn engineer about it. And I mean engineer, not salesperson! Redline's website shows at least some of their synthetic gear oils are suitable for use with clutch-type diffs, but they don't mention cone-type.some lsd vendors including auburn specifically recommend to use “non-synthetic” gear oil
