ATTN: Synthetic Users - How long is your OCI?
Some statistics so far...these are not necessarily scientific, so interpret however you like at this point:
1. Population Size: 38
2. Avg $/QT where specified: $4.92
3. Avg OCI Miles where specified: 8,270
4. Avg OCI Months where specified: 9.3
5. Min Miles: 5,000
6. Min Months: 4
7. Max Miles: 14,000
8. Max Months: 12
9. Std Dev Miles: 2,610
10. Std Dev Months: 3.4
I'll continue to update as I get more info. "Why?" you ask. Just because it's fun to look at the numbers, and because I have no life.
1. Mobil 1 Extended Performance 10w30
2. $5/qt
3. Chrysler 2.7
4. 15k w/Full flow change at 7.5k and MG changes every 5k
1. Mobil 1 Truck and SUV
2. $5.25 (That was last year)
3. Dodge 5.2 Magnum
4. 10k (1st run, expect to be on same schedule as above by next year, analysis permitting)
1. Rotella T-syn
2. I forgot, but it was cheaper than the Truck & SUV
3. Chrysler 440HP
4. Don't know, probably won't for at least a couple years. Will change the MG annually whether it needs it or not.
1. Rotella T-syn
2. See above
3. Plymouth 340
4. See above
1. Rotella T-syn
2. See above
3. Cummins 5.9
4. Don't plan to ever change it. With 6 quarts in the Gulf Coast, I think a full flow and roll of paper towels about once a year ought to do it.
Sorry if my schedules don't help much with the statistics!
1 - Shell Helix Ultra 0W-40 API SL.
2 - 14 Euro's a liter.
3 - Honda F20C (S2000)
4 - 7000 - 8000 miles. (now @ 2200 miles)
Will do a used oil analysis.
Before I used Shell Helix Ultra 5W-40.
OCI was 6500 miles. No used oil analysis done.
Maybe I will go to a 0W-30. I havent decided on a brand yet. Leaning towards Mobil 1 0w30 GL-4 API-SM.
1 - Amsoil Series 2000 0w-30/Series 3000 5w30
2 - Preferred customer price, about $7.50 per quart
3 - 1995 Mercury Grand Marquis 4.6 liter V8
4 - Once a year or 10,000 miles without a used oil analysis to back it up.
However I always perform a used oil analysis after each drain to keep a check on things.
Amsoil - various formulations, as I'm always testing something
Cost from $5.75/qt to $7.50/qt for the S2000/S3000
1990 Audi 100/2.3L and 2002 Audi TT turbo/1.8L
15,000 miles for the Audi 100 and 10,000 miles for the TT turbo
Been doing this since 1978....243k on the Audi 100 and counting...
1. Amsoil ACD (10W)-SAE 30
2. $4.50/qt
3. Volvo 2.5L I5
4. 1 year - whatever miles - 10K - have done 20K - may do much less this year - I am a Van Pooler - for $12.25 month, hard to pass up!)
1. Amsoil XLM 5-20
2. $4/qt
3. Honda (Ody) 3.5L V6
4. About 8k? (OLM is IN control!
used oil analysis after every change? Man, that can get expensive (relatively speaking), but you'll definitely be on top of what's going on in your crank!
243K with 10K to 15K OCI? Very nice!
quote:
Originally posted by LouDawg:
quote:
Originally posted by Oldmoparguy1:
2000 GC 3.3, Mobil 1 10W30, 7000 miles, then add A-RX for 1500 miles, total 8500 miles. Changed today. Put in 4qts. Formula Shell 5W30, 1qt. Rotella T 15W40. (Auto-RX rinse).
1989 Dodge Caravan 2.5 Turbo, Rotella T Syn, 5W40, 1 yr./5000 miles.
1994 Plymouth 2.5 TBI, ST Syn, 10W30, 1 yr./5000 miles.
Do you have/know prices? Thanks...
Mobil 1 78 Qts. @ $2.60/qt. Average (PB B3G3 free)
RTS $12.88/gal, Still have 3 qal. Bought in 04.
ST Syn, Bought 3 cases in 2003 on sale, $2.59/qt.
Formula Shell, $1.00/qt last year @ Freds.
Rotella T, $1.35/qt. @ Target this April.
1997 Volvo 960 2.9L I6 24 Valve
Mobil 1 10W30 W/LC
Cost $4.60 per quart
OCI every 6 months.
Next OCI in September I will be sending sample to Blackstone to see if i can extend OCI to one year.
1987 Volvo 745T 2.3L I4 8V Turbo
Mobil 1 10W30 W/AutoRx
OCI 5K miles
Factory recommended OCI 5K or 6 months.
I don't extend because of Blackstone report, oil shot by 5K due to the Turbo and mostly short trips (less than 3 miles) between work and home.
1. Mobil 1 10w30
2. ~$20/5qts
3. 1993 Mazda 2.0L used from 80-180k miles
4. 5k miles
1. Pennzoil Platinum 10w30
2. 3. 1993 Mazda MX6 2.0L 190k miles
4. 5k miles, next OCI will UOA at 7-7.5k
1. Mobil 1 / Mobil 1 Extended Performance mix 10w30
2. ~$3 buy3get3 coupons
3. 1992 Nissan 1.6L 180k miles
4. 7-10k miles
quote:
If you use exclusively full synthetic oil (including GIII) in any of your vehicles, please list:
1. Brand/type of synthetic(s) you use
2. How much you pay for it
3. Engine/application
4. How long your OCI is (OCI's are)
  • Mobil 1 5W-20 SM and Amsoil EA oil filter
  • USD$34.00/case
  • 2001 Ford Taurus - 3.0L DOHC
  • Current OCI to be 7K
Impressed by Redline 5W-20 oil. Under consideration for future OCI
REDLINE 5W-40; along with LUBE CONTROL LC-20
2001 DODGE RAM 1500 V8-318, 5,600# and 115,000
Seven to nine thousand, or, twice yearly.
1) GREEN GC 0w30
2) $4-$5/qt.
3) '00 Grand Am GT 3.4L V6 105K Avg. 20k/year
4) 10K (first run; previously ran Mobil 1 for ~7K)
1) Pennzoil Platinum 5w30
2) $2.12/qt (60+ quart stockpile from Pep Boys rebate taht Walmart price matched on the spot each time I went there)
3) '05 Mazda3 Hatchback 2.3L I4 18K Avg. 17K/year
4) 7500K (first run; maximum miles allowed per warranty)
Both vehicles are using an oversized PureOne filter. However, due to some start-up noise on the Grand Am, I'll probably go back to WIX on it.
Havoline 10/30 synthetic
less than $1 / qt
GM Powertrain LS1 / 2004 Pontiac GTO
3000 miles or every sixth month, whichever comes first
Havoline 5w30 synthetic
less than $1 / qt
Jaguar AJ V8 / 2004 Jaguar Xj8
every other month
Havoline 5w40 Synthetic
$1.99 / qt
Jaguar V12 / 1994 Jaguar Xj12
3000 miles or annually, whichever comes first
Pennzoil 5w30 Synthetic
$1.49 / qt
GM Powertrain 2.2 L / 1999 Chevrolet S-10
3000 miles annually, whichever comes first.
Everything else gets synthetic blend or straight mineral oil.
quote:
Originally posted by racer12306:
1. currently mobil 1 but i like the platnum
2. $18.97 for a 5qt of platnum
3. 2004 Dodge Neon 2.0l
4. 5000 miles for now but will bump it up to 7500 after the warrenty, unless i am doing my current commute of ~1.5 miles for a while, then i will do it every 6 months.
Do you mean you will be switching to PP at next change? If not, what price did/are you paying for M1, and what grade? Thanks...
i used platnum last change and it used very little oil. i wanted to see if the consumption was the same with Mobil 1 or if the car was finally fully broken in. The Mobil 1 was about $22 for a 5 qt. I have no reason to use Mobil 1 from here on out and probably will not touch it for the rest of the life of my car.
Rotella T Synthetic 5w40
14.8x/gallon
2002/1999 Jeep Wranglers 2.5/4.0
(intended) 6 months regardless of mileage 13k/18k year.
quote:
less than $1 / qt
every other month
$1.99 / qt
$1.49 / qt
Where do you get your Havoline Synthetic? And how in the world to you manage it for $1.00???
