I need two water sensors for the drip pans under the A/C coil & also gas furnace in my attic. The Little Giant condensate pumps have a 24V wiring scheme that is supposed to shut off the HVAC when either pump doesn't energize. However, if the check valve is bad, then the pump runs (is energized) but doesn't pump. So the HVAC will continue to run leading to water leakage. The drip pans are approximately 2" tall.
Any recommendations?
Thanks.
Thanks.
