Alrighty, I figure that the best way to keep my engine from eventually burning oil is to keep the oil as clean as I possibly can. So, I'm doing the following:
1) Using a MicroGreen filter on the car. It has a built-in bypass filter that is claimed to filter down to 1 micron or so.
2) I'm using a magnetic oil drain plug made by Gold Plug. I've confirmed that it's good to 302°F. I figure that will pick up any iron particles that fall to the bottom of the pan.
3) I have two Filter Mags on the oil filter. These too are good to 302°F, and the purport to pull almost all of the magnetic material out of your oil.
4) I plan on replacing the oil and filter as per the OLM of the car.
I'm also using Mobil 1 5w30 EP
I figure that doing all of these is my best shot at absolutely minimizing the amount of abrasive material in the oil, which should minimize the wear on the engine.
(Yes, I know that I'm "wasting" money - I'm doing it for gits & shiggles. I also know that some folks don't believe anything that MicroGreen says.)
I'd love to know your thoughts on this approach.
Comments?
Comments?
