Has anyone used 505 CRO (oil additive) and 505 CRF (fuel additive)? Is used to decarbonize the engine.
Did you use it? If yes, what's your results?Has anyone used 505 CRO (oil additive) and 505 CRF (fuel additive)? Is used to decarbonize the engine.
No, I haven’t used it.Did you use it? If yes, what's your results?
I have used it several times on several vehicles. I can say this, nothing on the shelves at any parts store comes close to doing what ATS Carbon Clean said it would. My Honda Pilot no longer burns oil after using this treatment. I've seen fantastic results in regards to MPG. I usually buy them 2 at a time to get the shipping cost down a little. Best place I've found to buy is here https://www.atscarbonclean.com/carbon-clean-shop/Has anyone used 505 CRO (oil additive) and 505 CRF (fuel additive)? Is used to decarbonize the engine.
DIY Dave gave it a go and it didn't do anything. Here is his exact video.
I'm attempting to get him to try HPL.. He is a very busy guy, however (for his situation.)
Here is that:
Like what?I have used it several times on several vehicles. I can say this, nothing on the shelves at any parts store comes close to doing what ATS Carbon Clean said it would. My Honda Pilot no longer burns oil after using this treatment. I've seen fantastic results in regards to MPG. I usually buy them 2 at a time to get the shipping cost down a little. Best place I've found to buy is here https://www.atscarbonclean.com/carbon-clean-shop/
Where do you see this? When I purchased it was well under $100.$300 for the oil and fuel treatment. That's a lot of snakes.
Well you do have Scotty Kilmer's testimonial as a backup, so there's that.Compression readings on cold engine is not the correct way to test compression. Compression readings are taken on a warm engines to allow everything to seal so you get an accurate reading. This video testimony isn't how a professional technician would tests an engine or a product for that matter.
Their websiteWhere do you see this? When I purchased it was well under $100.
It’s $60 there. The $300 option is for a case of 12.Their website
Doh! That's a big difference and way more reasonable.It’s $60 there. The $300 option is for a case of 12.
It is direct contact. It is intended to be used in a running engine for a short period of time.In reality, any pour-in engine flush or fuel additive will have limited effectiveness compared to a direct-contact soaking of components. Feel free to experiment (at your own risk), but I wouldn't expect miracles.
No it’s not - it is mixed with engine oil.It is direct contact. It is intended to be used in a running engine for a short period of time.
