I would like to try using ATF in the primary chain case of my motorcycle. The factory enlarged the engine to twice the original size, but basically left the clutch the same size. I use up a clutch every year and would like to try to make them last longer. The drive chain free play is taken up by adjusting a hard faced steel shoe against it. Presently engine oil, 20w50, is used for lubrication. Do you think an ATF would offer enough lubrication to stop the chain and adjusting shoe from wearing prematurely?
TIA
Hylton
TIA
Hylton
