ATF for 2003 Altima
Brampton, Ontario, Canada
I am wondering if Dexron III is the same thing as Nissan D Matic, since owners manual says that either Nissan Matic or Dexron III can be used.
Would AMSoil synthetich ATF be a better choice than Mobil 1 ?
AMSoil claims that it can be used wherever Dexron III/Mercon or ATF+4 are called for, now Mobil 1 makes no such claims but I would still lean towards Mobil 1.
Any thoughts??
Any thoughts??
Take your pick between Amsoil and Mobil. Both are good ATF. I have Mobil in my '02 Maxima since 15k miles and I have now 32k with no issues. I feel the transmission shifts better than with the OEM fluid. But I have also heard from people using Amsoil in their Maximas with no issues. It basically comes down to price and availability.
Nissan D Matic and Dexron III are interchangeable, however Nissan is pretty particular about Nissan D Matic being used for warranty reasons.
So, if your car still falls under the factory powertrain warranty, then i would use the D-Matic fluid.
It's pretty good stuff alas a little pricey.
Dominik : Try this out...
Chevron Dexron III(H) + Lubegard Black
You may have a tough time getting GM's H speced fluid but I did see it being carried by Kragen Auto Stores for $1.67.
The above is an excellent combination!!!!
