I have a 2002 Tahoe with 239k miles on the original 5.3L and 4L60E transmission. Neither one are showing any signs of poor health. *knocks on wood* It serves as the family vacation vehicle, but also as the tow rig for my track car. The car, trailer, fuel, tools, etc... totals right at 6,000 lbs and the tow distance is 80 miles round trip to the nearest track (10-14 times per year) and 900 miles round trip to the furthest track (once per year for the LTx Shootout). The trip to the local track is all flat highway. There's some small mountains on the long trip going across northern Georgia and eastern Tennessee, but nothing major.
The engine I'm not concerned about. It's a stout workhorse. The transmission however is notorious for burning up the 3-4 clutches, and 99% of the time it's due to excessive heat. When I tow with this transmission, I keep it in tow mode around town and do tow in overdrive on flat highway. If I notice it jumping out of lockout, hunting for lockout or 3rd gear, I'll manually drop it to 3rd gear. This Tahoe has a tall 3.08 rear gear with 31" tires so 3rd gear at 70 mph is still only around 2500 rpm. In OD, it's about 1700 rpm.
My intention is to keep the transmission temps down to extend transmission life and help it tow easier. The OEM setup cools the ATF through the radiator which I'm sure isn't the most efficient. I plan to get a deeper oil pan with a drain plug to hold an additional 2 quarts. Would additional capacity, paired with a high quality ATF, be sufficient for this application or is a secondary external ATF cooler a necessity? Any thoughts on using Red Line D4 ATF in a 4L60E at 30k mile oil and filter change interval?
