Guys, I have a quick question. I'm a electrical engineer by profession but it is driving me crazy since I'm trying to figure out how or where the new/old fluid goes after you add new after pan drop. Have I confused you yet lol??? Ok let me break it down into Layman's terms...
-after you drain the old fluid from the pan and put in the new atf fluid thru dipstick, it goes directly to the transmission pan right...so after you start your car and let it run for 5 min, does the new atf fluid go to the TC and old atf that was in TC go to the transmission pan???
The reason why I ask is because of the multiple drain/refill when changing atf. How do you know that you are not replacing new aft that's mixed with the old atf or each time you are doing the multiple drain, you're draining the old fluid?
