02 Camry at 106 (got it at 100). It was flushed at around 60. So last time I changed the oil I drained the ATF. So I drained it again today and it was red but still looked fairly dirty. What do you figure, drain again in 6 months?
Can't believe how dirty ATF fluid must be in my other rig that doesn't have a drain bolt and other rigs that don't keep up with it.
And...while I at it...
I used the same funnel I used for the oil. I just cleaned it best I could, is that fine? And..Why do they recommend going through all the gears after filling?
And...Our recycle center doesn't accept ATF..just oil and cooland. What should I do with it?
