ATF change in a Honda
Originally Posted By: JOD
Both of those used oil analysis seem to contain only a portion of DW-1 (a single drain/fill, or 30-40%?), and the viscosity of DW-1 is 6.8 out of the bottle, so I don't think this is really much evidence that the fluid shears heavily. If anything, considering the viscosity of the remaining fluid, I think just the opposite may be true. We'll probably need to seem fo used oil analysis on units with all DW-1 to really tell. I will say that the DW-1 seemed to improve shifting (which was already pretty good) in an older CR-V.
I can yield to that (partial fills of DW-1). The MSDS for DW-1 shows a 6.8 cSt virgin viscosity, but I swear that I read that it was closer to 7.5 or more. I could be wrong on that (and apparently I am).
That begs the question about the Castrol Transmax IMV product. If its viscosity at 100 deg C is 8, how are they saying that it meets the specifications of DW-1, a fluid that may start out some 15% lighter?
I could run the DW-1 in our CR-V just fine; I generally like how it shifted in that car. I simply use the Castrol because it's easier to find. But in the Acura, I just didn't like how DW-1 performed in it. As the fluid got hot, shifts got pretty sloppy. I wasn't all that impressed with it as time wore on. I think the fluid was getting degraded. If I changed the ATF every oil change, it might have been better, but I can't justify that. The MaxLife runs very well in the Acura, and its performance doesn't degrade over time like the DW-1 did.
"Shift quality" in terms of smoothness certainly improved with DW-1 in the Acura. It improved so much, you couldn't even feel them. You could hardly tell when the transmission shifted under most circumstances. Under more pressure (long trips with hot fluid), you could actually feel it shift, but only because it was shifting slowly. The shifting didn't feel "positive" like it does with MaxLife.
Just one more point: I use Honda fluids everywhere else (coolant, brake fluid, differential/transfer case), and Honda air filters. Also have a stash of Honda oil filters I will end up using. I'm certainly not adverse to OEM products, and in fact generally favor them.
Maybe I'll venture back into DW-1 land, I don't know. Keep talking; maybe you guys will convince me.
I would do 3-4 drain and refills with 1k-3k in between each drain. This would give the new fluid additives time to clean up whatever the old fluid left behind. Anything cleaned behind would be suspended in the fluid and be drained out during the drain.
This would be safe enough to maintain a healthy transmission. After the last drain and refill, I would continue to follow up with 1-2 drain and refills every 15k miles.
Clean up the drain plug magnet each time and you should be good to go.
