Greetings:
Just some background: I have a '96 Jeep Grand Cherokee 4.0L with the 42RE transmission and 170K on the clock. The current fluid in there is ATF+4 with about 35K miles on it. I did a filter change and band adjustment at that time and bumped up the line pressure adjustment a bit based on many recommendations that I have read. The transmission shifts great - nice and firm. The truck has a Long Tru-Cool external stacked-plate cooler that I also installed at the same time. Driving is 70% highway/30% city. The climate is typical NE Pennsylvania. Lowest winter temps are around 0F and highest summer temps are probably 90-95F but normally in the mid 80s. The truck is not wheeled and it has only been used to tow briefly a couple of times.
Any thoughts on how often this fluid should be changed? From looking at it on the stick it looks pretty much like it did 35K miles ago. Would 50K be safe?
Thanks in advance for any advice.
Andrew S.
Andrew S.
