Originally Posted By: Johnny2Bad
91 RAM? Are you sure Chrysler/Dodge recommends ATF+4?
+4 is basically a Mercedes-spec transmission fluid and was introduced during the MB/Chrysler years around 2000 or so. My 96 RAM spec's ATF+3 in the manual, which is a substantially different lubricant.
If your rebuilder suggests Dexron 3, I'd follow his advice, although jrmason's post is interesting. You definitely don't *have to* run ATF+4 in a '91; that fluid didn't exist when your truck rolled off the assembly line. Check your manual (or download one).
ATF+3 has been discontinued for about 10 years now. ATF+4 supercedes +3 and is similar in performance characteristics except +4 retains the characteristics for at least 100,000 miles where as +3 typically was only good for 30k miles.
