Staying thinner than 6,000cP is all you need.
Most 5w oils are getting pretty close to 6,000cP at -20f.
That’s the Brookfield rating eh? I think my Valvoline Restore and Protect 5W30 is just over 6kStaying thinner than 6,000cP is all you need.
Yeah if its only going to get changed once a year i say do it right before it gets cold.Just stick with 0W-XX year round. Or if you do multiple oil changes per year just put 0W-20/30 in there when you change it in the fall and use 5W-20/30 when you change it again in the spring.
How do you know it starts losing its pumping ability? How would you even begin to test that?Yeah if its only going to get changed once a year i say do it right before it gets cold.
One of the first thing oil seems to lose is its cold pumping abilities.
I'd rather run fresh 5w then a burned up year old 0w.
I think it’s based on viscosity changes from heat cycling…How do you know it starts losing its pumping ability? How would you even begin to test that?
I don’t understand that either. What does heat cycling do to the viscosity that causes it to change? And then affects the pumpability?I think it’s based on viscosity changes from heat cycling…
Its so simple even you can do it.How do you know it starts losing its pumping ability? How would you even begin to test that?
Actually there is a way to test it, but it involves a seized engine.
You also don’t know what pumpabilityIts so simple even you can do it.
Take a fresh quart of oil and a used quart of the same oil, put both in a freezer and see how much thicker the used oil is. You'll see the used oil is significantly thicker.
Not being able to do the pump ability test doesn't mean mean I don't know what it is. Try another strawman.You also don’t know what pumpability
means.
The goofy freezer test notwithstanding.
Indeed.Not being able to do the pump ability test doesn't mean mean I don't know what it is. Try another strawman.
Have a link to pump ability tests of used oil compared to new oil?
Seems like you would have lead with that if you did.
Then why did you bring up a freezer and pour test?Not being able to do the pump ability test doesn't mean mean I don't know what it is. Try another strawman.
There's no problem running 0W-XX year round as you said. They're good even for very hot summers. The best thing about them is better cold start flowability compared to 5W-XX oil, even in the dog days of summerJust stick with 0W-XX year round. Or if you do multiple oil changes per year just put 0W-20/30 in there when you change it in the fall and use 5W-20/30 when you change it again in the spring.
Not necessarily. A grade with a 0W rating may be thicker than the 5W except at the testing temperature for the rating. Above that there is no guarantee.There's no problem running 0W-XX year round as you said. They're good even for very hot summers. The best thing about them is better cold start flowability compared to 5W-XX oil, even in the dog days of summer
