Assembly lube as moly additive?
Retiredville SC
If you feel the need to fortify the moly, maybe grab some Schaeffer's 132 Moly E.P. oil treatment. Seems to work for those fokks that have used it.
We've seen many used oil analysis on factory fills show up with a lot of moly, due to the moly in the assembly lube.
So would adding a tiny bit of assembly lube be a safe way to beef up an oil that's low in moly?
MR
