This post is intended to be a summary of what I've learned, and presents some new/additional/refined info that Slacktide sent me in a PM.
If any of my info below is incorrect, then please correct me.
Slacktide sent me a very useful PM
about maintenance schedule. With his permission I'm publicly posting it below so all may benefit.
Service Life of Coolant - Follow the vehicle's recommended service interval.
In this case the vehicle is an 03 Honda CR-V.
For your 2003 CRV, Honda says the first coolant should be at 10 years or 120k miles, and subsequent coolant changes should be at 5 years/60k miles.
Go to page 238 of the
2003 Honda CR-V Owner's manual
2006+ Hondas have an automated maintenance minder instead. For those cars with the MM, it's code 5. (I interpret that to mean change the coolant when MM tells you to, which is indicated by a code 5)
The standard vehicle maintenance schedule applies whether using Honda OEM Coolant or any brand of Asian Blue Coolant. It also applies regardless of # of years claimed on the jug of any brand.
To say that another way, change Asian Blue coolant as often as you would change Honda OEM brand coolant.
Although there is some debate about this, I'm of the opinion that I only want to use a brand of Asian Blue that does
not contain 2EHA because 2EHA is widely reputed to be harmful to plastic, gaskets, and maybe rubber, which could result in leaks.
Peak, Zerex (Valvoline) and Pentafrost do
not contain 2EHA. So those brands are good choices. I would buy whichever of those is lowest cost. Walmart is likely to have lowest prices, but autostores sometimes have sales. NAPA sells Peak. Oreilly sells Zerex. I don't know about other autostores.
Supertech (Walmart store brand) Asian Blue does not contain 2EHA if it's made by Peak, but Supertech would contain 2EHA if made by Prestone. I don't know who makes Supertech coolants.
So I don't know who makes Supertech or if it contains 2EHA. Hopefully that will become known for sure.
Who makes Supertech coolant? More importantly,
does Supertech Asian Blue contain 2EHA?
Prestone defineately contains 2EHA. So I would avoid it.
There are many other brands of Asian Blue. I don't know if they contain 2EHA or not. So I don't know if they're good, or not.
Lastly, the consensus is that it's fine to mix different brands of Asian Blue coolant, which makes sense to me. However, I would avoid brands that contain 2EHA.
If I left anything out, or you think I'm incorrect about any of the above, please let me know. Thanks!
