Can running the 3 oz. maintenence dose of Arx affect the true readings of a used oil analysis?(oil capacity of my Ford 4.6L sohc is 5 qts)
I'm currently at the end of my Arx rinse, and getting ready to go from conventional to synthetic.oil(in this case GC, probably would run it for 3k miles), and want to be sure that my motor/seals stay clean.
if it could affet a used oil analysis, which values are most likely to be affected?
Thanks for any ideas.
(I wasn't really sure where this topic should be; pls move if it should be in additives or used oil analysis-sorry)
