We have enabled Article type threads in Used Oil Analysis - Gasoline and Used Oil Analysis - Diesel. The purpose is so that you can keep a running used oil analysis (UOA) history of your vehicle in one thread. You'll be able to add to and edit your original post as long as you are a member on BITOG. We think it will be beneficial to see the entire UOA history of a vehicle in a single post, instead of a new thread every time you get a new UOA.
We would appreciate if article threads aren't used unless you intend to add to your original post over time. If you are not going to update your thread in the future, then please use the type "discussion" instead of "article".
