All,
We would like to get your opinion on a proposed new forums feature. Xenforo has the ability to make the first post in a thread be an "article" post. The article post is formatted differently to allow for more space and better handling of photos. The original poster information is removed on the left, so the focus is entirely on the article. You can see an example article post here:
There are no photos in my article post, but you get the idea.
The use of article posts would be limited to special cases, such as a single article post for all of the oil analysis history of your vehicle. You could make an article post for the first oil analysis, then edit the original post later and add the next UOA when you get the results.
Another use case could be for long educational articles such as those written by Overkill, Molekule, TomNJ, Clinebarger and others.
Towing Safely
I put this together because I couldn't find anything out there that puts all these points together in one document. Take a look and let me know if you'd change or add anything. Towing safely Weight Compatibility One of the most important factors to consider when towing is the weight rating of...
rvthe.us
