A Subaru doesn’t stop faster than any other car in the winter. Real nice to not drive over a family of 4 due to wrong tiresIf all you’re worried about is the 27* incline on your driveway, lay out 3/4” PEX in a continuous pattern like a heating element would be, then have a local contractor pour you a 3” thick topper over the PEX. Fill the loop with straight propylene glycol. Connect it to a micro boiler and either have a manual switch to turn it on, or set a temperature sensor in the concrete to turn the boiler on when the concrete goes below 35* and off over 40*. If you don’t want a micro boiler, technically you could do a couple solar hot water collector panels but then you’ve got to keep those clean if you want heat in the driveway. Never have to shovel or worry about making it up your driveway again!
I had snows on my Odyssey, and snows on my 93 Mustang. They didn’t really make a huge difference in turning, but they did transform the car’s ability to go. Stopping was better but nowhere near as stark a difference as acceleration. Never had snows on any Subie, because if you “need” snows on your Subie, you probably shouldn’t be driving in the winter anyways![]()
What are you talking about? Maybe read the rest of my post. Snow tires don’t prevent idiocy in any form of winter driving: not acceleration, not turning, nor stopping.A Subaru doesn’t stop faster than any other car in the winter. Real nice to not drive over a family of 4 due to wrong tires
So, what you saying is that people who drive 30mph and kid runs out in front of them drive like an idiots? And they don’t avoid panic situations and they lock up brakes?First of all I don’t drive like an idiot when it comes to bad weather. I try my best to avoid panic situations and don’t lock up the brakes. It’s worked for me the last 18 years I’ve lived here.
That should only be around $40K at current concrete prices. I'll get right on that.If all you’re worried about is the 27* incline on your driveway, lay out 3/4” PEX in a continuous pattern like a heating element would be, then have a local contractor pour you a 3” thick topper over the PEX. Fill the loop with straight propylene glycol. Connect it to a micro boiler and either have a manual switch to turn it on, or set a temperature sensor in the concrete to turn the boiler on when the concrete goes below 35* and off over 40*. If you don’t want a micro boiler, technically you could do a couple solar hot water collector panels but then you’ve got to keep those clean if you want heat in the driveway. Never have to shovel or worry about making it up your driveway again!
That’s a good Dad, right there. I put Viking Contact 7s on the SUV my daughter drives. I want every advantage for her safety. Just like you do for your daughter.My daughter called me yesterday saying "thanks dad". Nothing was really forecasted for her area but mother nature doesn't care so much what we predict. She was leaving class and the road leading uphill from lot was closed, multiple accidents, cars sliding everywhere and now blocking. Her 2 friends waved her down as they couldn't even get out of their parking spots. She stopped and said it's not that bad and picked them up. She went down the hill to side road and up a larger hill in her '08 CRV. Her friends were bewildered. She told them because my dad loves me and worries about me.
She did say that the fronts spun a bit going up the hill but knew that was needed to get the rear to activate also on the "real time AWD" which has pumps in rear diff to put pressure on clutch packs. She said no issue going down hill but did go slow and used low gear. Her CRV has 4x VikingContact 7's on it.
Snow tires are, first and foremost, about stopping!View attachment 258135
Compared to my CC2's, longitudinal traction (accel/decel) is very similar. Probably matters more what "type of snow" you're on than what tire you're on. Lateral (turning), I give maybe a 5-15% advantage to the WS90's. Snow tires are only worth it if you have a FWD vehicle like this one and are clawing for every ounce of advantage you can get. Otherwise, CC2's on AWD are more capable.
On ice, I'd give the WS90's a 5-10% advantage.
Long story short, WS90's on a FWD strike me as a good move as I want every ounce of advantage. On my AWD cars? Waste of money. CC2's are 90% the tire, and AWD more than makes up the difference. PSAS4's are 85-90% the tire CC2's are in snow and ice, in my experience, as long as the tread is 6/32+.
*This is based on subjective driving feel in the Ozark mountains, I left my tape measure at home.
The internet is full of crap about CC2's and modern all weather tires "not being good enough", is my take from this little experiment.
Imagine putting four Blizzak WS90s on your AWD car. You'd gain back the missing 10%, in addition to having the other axle powered too vs. the Buick. So, maybe 110%?Long story short, WS90's on a FWD strike me as a good move as I want every ounce of advantage. On my AWD cars? Waste of money. CC2's are 90% the tire, and AWD more than makes up the difference.
Meh. Judging by braking, which is all 4 of course, it wouldn't do a ton.Imagine putting four Blizzak WS90s on your AWD car. You'd gain back the missing 10%, in addition to having the other axle powered too vs. the Buick. So, maybe 110%?
Believable.Snow tires are, first and foremost, about stopping!
The difference in testing by Tire Rack between WS90 and CC2 is 18ft on ice and 10ft in snow.
The acceleration to 12mph, WS90 are only 4ft faster.
The difference in stopping between CC2 and Pilot4 AS in the snow is only 2ft, and ice is 2.7ft!
The aggressive CC2 design means good forward traction, but again, many AS tires have good forward traction, or AT tires.
I thought this was all about your 27% incline?Meh. Judging by braking, which is all 4 of course, it wouldn't do a ton.
No way any car without awd is going up that with or without snows. So I parked at the top, but my neighborhood and commute still has some very steep inclines.I thought this was all about your 27% incline?
I’ve made it up very steep, icy, winding roads, (I used to live on one), with a 2WD and snows, while AWD without snows used to crash on that road with regularity.No way any car without awd is going up that with or without snows. So I parked at the top, but my neighborhood and commute still has some very steep inclines.
