I'm basically saying not all API/SQ oils are the same and that some would meet/exceed certain Euro tests IMO, however some of the tests are also different. The IIIH is used for API/ILSAC. The Euro OEM's have their own testing.
See this thread:
Came across this from engineering explained on youtube. Some may find it interesting so ill share it here
- travis8352
- Forum: Passenger Car Motor Oil (PCMO) - Gasoline Vehicles
Here is an example. Could ESP do a double length IIIH test and still score 40% better in terms of piston deposit cleanliness? Who knows.... That's 180 hours of oil held at 305F.
Mobil 1 Triple also crushed the IIIH. 20x better in terms of oxidation thickening.
Disclaimer: I'm not trying to argue with you or troll. Just trying to have a discussion. Given my recent experience in my thread soliciting Supertech experiences, just wanted to make that very clear since tone is poorly communicated online.Most people are saying that all our API/ILAC oils fall in the blue. I'm saying, no, many would exceed and hit the yellow parameter. They don't just meet bare minimum. When you buy Mobil 1 Extended Performance you should be getting an oil that greatly exceeds these tests.
My disclaimer is I don’t like brand bashing - but let’s be honest about Subaru pistons, ring lands, detonation, oil consumption - all that. Some of the very experienced techs talk more about oil starvation than what oil …Disclaimer: I'm not trying to argue with you or troll. Just trying to have a discussion. Given my recent experience in my thread soliciting Supertech experiences, just wanted to make that very clear since tone is poorly communicated online.
I don't think anyone is arguing Amsoil isn't a good oil. I think the crux of the matter comes down to whether or not you need that much headroom. Determining that I think is the really hard part. Basically, in my view, there are people who will be fine on bulk oil, then some that would do better to run ST/Kirkland or a basic oil like QSFS/vanilla M1, then some who will need Mobil 1 Extended Performance to be free of issues, then some who need Euro oils, and then beyond that some who will need Amsoil/HPL to have no issues. I think that the Subaru engines are good examples of this. You can see @Glenda W.'s experience. She started burning at 60k. Her friend on Mobil 1 Extended Performance, started burning at 120k. Then, when you have someone in a 2014 Subaru Outback running Amsoil, they don't burn oil. So you can see the progression in apparent oil quality and delay of onset of oil burning. Additionally, @OVERKILL got a ton of crud out when he first ran HPL after a diet of Mobil 1 Extended Performance. (Not sure if he was burning oil or had other issues or not.) Then you see other engines with design issues like Kia/Hyundai, and they burn even earlier on Mobil 1 Extended Performance.
Besides HPL or a monograde, can you think of any other diesel oils that don't shear or shear very little?I sure haven’t seen countless UOA where the oil has sheared out of grade. I seen many where there is fuel dilution which causes it to thin, but very few where there is confirmed mechanical shear of the VM.
If you really have a mechanical shear problem then something like HPL no-VI is a good choice. That won’t shear, nor would a monograde oil, assuming you could find an appropriate one.
Either way if you’re seeing an oil go out of grade, it doesn’t make much sense to doggedly stick to the manual recommendation.
Oh come on guys, get with the times! Get a fumoto drain valve and a short hose to stick in the empty oil jugs from your last fill and you can drain the oil as hot as it can get with the contaminates all nicely circulated and entrained with the thinner oil rushing out! No burns, no splash or drips. Bada bing Bada boom.I do it fully cold regardless of temp outside (though TX doesn’t get that cold) and just let it drain while I do other things like check filters, tire pressure, general inspection. Occasionally, if I don’t have it set up just the way I want it in the driveway, then I might start it up to move it around.
Just a head's up if you didn't know, but we have a whole forum dedicated to diesel oils here. I bet you could find some info there from searching, and if not you could ask.Besides HPL or a monograde, can you think of any other diesel oils that don't shear or shear very little?
I have a 7.3 Powerstoke and it is rough on oil. I've been leaning towards going with HPL but am wondering about other options.
Oh yeah, I know about the other forum.Just a head's up if you didn't know, but we have a whole forum dedicated to diesel oils here. I bet you could find some info there from searching, and if not you could ask.
Also, 15 quarts of HPL, ouch.
I just figured after 5 pages into this discussion with all of the usual opinions, bickering, making up, some great info, some wrong info folks will fall on the sword for, etc., I'm in this one for the long haul now so figured I'd ask.
And yeah, 15 quarts.....
The Google-fu was strong tonightDang, you are efficient! Thanks!
I haven't been afraid to try different oils, weights or additives with my truck so I definitely have an "opinion" (key word) on what I like but I'm always willing to listen and learn.
You don't have many choices if you really mean an oil that cannot shear. How is your Powerstroke rough on oil?Besides HPL or a monograde, can you think of any other diesel oils that don't shear or shear very little?
Sorry no way...I assure you all of those claims are not valid with me and my oil still gets dark within 1k miles or sooner. It's the animal within the Honda 1.5 tgdi... that causes it...If the oil was dark at 1000 miles this tells me a few things:
1) The OCI's were beyond what most of us do here.
2) Cheap Oil was Used
3) The oil was never checked between OCI's
I am positive on Number 1 and 2, Number 3 is kind of a guess.
The 7.3 easy on everything mainly because it's only 220 horsepower, but as with all the HEUI platforms, the HPOP and injectors can place unique some demands on the lube oil.Diesels are not my wheelhouse. I thought from the info I’ve gleaned about them on here, that the 7.3’s were “easier/better” on oil due to being pre-DPF and emissions systems. No regen cycles and all that?
Always found it interesting that BMW chose to include an oil cooler (oil to water) on the front of the OFH on some n52 cars, but omit it on others. Piston jets but no oil cooler didn't make sense to me. I went as far as to add a cooler from an x5 onto my 2011 e92 328.Late to the discussion. Our 2011 BMW 528i was the last year of the N52, the NA inline six. Oil temps typically stay at 240F on interstate runs of about 85mph. Always run 0-5w-40 LL-01 oils.
PS: Sorry for all the typos fellas.Short answer:
Absolutely.
this truism has been long known, this is my Turbo engines generally ( used to?) spec one or two grades thicker than the non turbo engines.
A turbo engine in summertime to me with me a Mobil 1 15w-50 oil, or similar.
If non GDI and all long trips a 5w-40 might also do.
If it is that much of a concern, then if it were me I'd run the HPL product if the 10W winter rating is acceptable for your climate. That will not shear.Yeah I'm looking for oils that tend to shear less.
The 7.3 is unique where it has a separate High Pressure Oil Pump (HPOP), which basically uses the engine oil after it has been pumped by the low pressure oil pump, as hydraulic fluid to cycle the injectors. The HPOP is a swashplate design.
The condition of the oil has a major affect on how this engine runs.
