Probably not to the extent that you can realize with the Ea0 filters. That is, the Trasco doesn't give you a linear level of filtration. As the tp section saturates, more and more flow goes through the full flow part. The EaO filter, OTOH, can only improve as it ages.
So, PROBABLY, the Trasco is better than a standard filter. But keep in mind that there's a fairly wide variance in standard full flow filtration. The PureOne, M1, and now the EaO filter are a substantial cut above the $2-3.x filter. The EaO appears to be out front in this group.
Now as far as "being worth it"?? That's debatable. In most cases you're providing a really clean engine for the next owner or whomever pulls it from the junkyard. "He died in perfectly good health"
If you're someone who keeps a car until it can't pass a safety inspection due to structural defects or parts are so obsolete that they can't be found..then, YES, it's worth it.
It all depends on how you view an automobile. I hope to never buy a new car again in my lifetime out of need. Out of desire? That's another story.
If you want a Trasco ..buy it and use it. It will be better than standard filtration. The cost:benefit ratio is rarely in anyone's favor here given our typical ..even extended .. engine life cycles.
my
