Are those cheap ebay clocksprings worth using?
So, the Subaru design has problem and need a more frequent replacement? or just your Subaru has a bad one?
If it is not a common design problem I would just get a used one pulled from a junkyard (that is still good), or look for a specific redesign one if it is a bad original design rather than eBay aftermarket.
I have never heard that this is a wear item on any car I owned.
This seems to be very common in the SJ Forester and other Subarus of the 2010s. They all do it :sneaky:
If the price difference is big and it's not hard to do again i'd roll the dice.
They're easy. 99% of the time I just bang all around the wheel and it comes off. Rarely need a puller.
The price difference is usually $30‐40 vs $200‐300. As these are often older vehicles, people don't want or can't afford OEM.
To be fair, I haven't seen the Subarus trigger an airbag light. But in the case of a Tundra with an airbag light, presumably the system has been disabled. Now, if the cost of OEM is high enough that the owner says "I'll just deal with it and do nothing" (as is the case in my experience) OR aftermarket makes it inexpensive enough they'll try a fix, which is worse? Now you're looking at guaranteed no airbag vs normal operation.
Let's also remember that we're often talking about vehicles that are 11 to 26 years old with high miles. In the case of Subarus it may be an older vehicle but with very low mileage, in which case OEM still feels like the definition of insanity: replace with the same failure-prone part and expect a different result.
So I just did a search for aftermarket clock springs that would be good enough, and StandardBrand dot com came up. Jumped down the rabbit hole and lo and behold, they MUST be good, as their version for my 4Runner retails for $600 to $750 😇.
Mileage may vary for the Subarus, maybe worth checking.
I didn't find a Standard/SMP clockspring, but I did find Shee-Mar which claims to be an OE supplier and has been around since 1970 :unsure:
Shee-Mar does kind of sound like a cheap Chinese knockoff name, and that $100 clockspring could be the same thing as ebay or reboxed OE or anything in between :cautious:
As seen on the MrSubaru video, the OEM clockspring is made in the Philippines, but I don't know who the supplier is.
I've used SheeMar pdl actuators in Focii (which are, of course, the entire door latch assy). They seemed "fine" but I can't attest to longevity. Sometimes in applications which are no longer supported by OEM they're one of the few options. And I'll always try SheeMar over Dorman!
I've lost faith in SMP for the most part. I think they still have a better chance of being decent, but they're no longer guaranteed quality. That said, I'm not sure I've ever seen an SMP clock spring, but I suffer from CRS
This seems like such a simple, basic part you'd think it should be more like a hundred bucks and not some multiple of that.
It's a very simple part with very stringent requirements as far as materials go. Material tension, durability, resistance, gold plated where needed - the perfect candidate for passing savings down to the client's safety 😇
Okay, but $600.00 worth of stringent requirements?
Absolutely not, of course. I'll chart more than half of it to stocking fees and such - if we're talking about my 30 years-old 4Runner. Parts get more expensive for older cars.
I used to work IT in a parts warehouse back in France in a different life, and we had a legendary full exhaust line for an Opel Ascona (a cheap econobox by then already 20 years old) that was carried around unsold from year to year, becoming more and more expensive as years piled on. Not sure what the exact deal was but I remember that the parts manager or whatever was getting red in the face any time he'd hear about it. They couldn't trash it, they couldn't sell it.
A new original clock spring for my BMW is less than $300 retail and like $150 if searching online.
And since it's hidden, you can use the same part on a Ford Fiesta that fits a Jaguar. Just leave a couple extra conductors. Use the same part for 20 years and the price will come down.
It's pretty normal for there to be commonality across a manufacturer's lineup for this type of part and I doubt that they get a lot of redesign.
Heck, how many high buck cars use the switchgear from cheaper models, maybe with a different customer facing piece?
If a failed clockspring results in inoperative airbags, shouldn't that be a mandated recall, if it is a pattern failure in Subarus?
Maybe file a complaint with NHTSA?
Subarus usually just lose the horn. Presumably if airbag was inop you'd get an airbag light.
However, yeah, Subaru was forced to essentially give a lifetime warranty on seat belts after they failed to retract and the belts tended to fray. Those models are now so old most dealers don't know about it, so you have to stand your ground on that one.
I suppose if it applies to seat belts in Subarus and consider all the Takata airbag recalls in other makes -- I guess a clock spring could be similar IF it's actually triggering an airbag light.
OTOH in both the case of the '11 Outback and the '13 Highlander the owners wanted it fixed because they tried to honk at someone who was merging into them and discovered their horns did not work. They then felt unsafe not having that ability to potentially communicate with other drivers. So there's a solid argument to be made that a functioning horn is a safety item.
According to Google:
"Every state with an active vehicle safety inspection program checks for a working horn. If your state requires a periodic safety inspection, your horn must be operational to pass.States with safety inspections verify the following:Audibility: The horn must be clearly heard from a set distance, usually 200 feet.Accessibility: The horn button must be within easy reach of the driver.Prohibited Devices: You will fail the inspection if you use a siren, bell, or unreasonably loud warning device reserved for emergency vehicles.States with periodic safety inspections include:
Delaware
Hawaii
Louisiana
Maine
Massachusetts
Missouri
New Hampshire
New Jersey
New York
North Carolina
Pennsylvania
Rhode Island
Texas (safety requirements still apply in many metropolitan areas)
Vermont
West Virginia"
