Arctic Cat Diamond Drive Fluid
MI
Does anyone know what arctic cat diamond drive fluid is? I am wondering if there is something better that i can use.
Gear lube with a catchy name.
from AMSOIL website
Synthetic Chain Case Oil (TCC)
Extreme-pressure additives promote long chain and gear life
Inhibits rust and oxidation
Low-temperature fluidity ensures maximum energy efficiency
Lasts longer than conventional oils
Recommended for Arctic Cat® Diamond Drive gearcases
Well..its a non hypoid gear that runs fairly cold.
A syn 75w-xx GL4 or a good atf should do it.
I use STOU or THF in my chaincases and besides getting
water inside em, no problems at all. But these are the regular
ones with a chain, no diamond drive.
