Hi,
I did some research a year ago and concluded that calcium sulfonate has to be the greatest thing for marine use. Water resistant and anticorrosive (thanks to sulfonates). Could not help but noticed that Walmart stocks Lubrimatic brand (dark green and stinky) for a decent price.
So, I repacked my new boat trailer bearings with Lubrimatic calcium sulfonate and keep using it via stock EZ-lube fittings. However, I noticed that after a few towing trips the grease becomes slightly softer and turns black. It is not mixed with water though. No oil separation either. BTW, I did that Bob's palm test and this grease does not mix with water at all and it is tacky. The bearings seem OK and run cool. I guess the softening could be just the natural propensity of this grease after being worked out in the bearings.
Anyone heaving a similar experience?
Is there a reason to switch to an aluminium-based grease (as preffered on this forum).
Should I repack freqently? It is very easy with EZ-lube (duh!).
Thanks
Thanks
