http://shop.advanceautoparts.com/webapp/..._T|GRP2042_____
Hope that works. If not it is the 12,000lb Blitz Rhino Ramp set.
My floor jack is giving out and can't lift my OB high enough for my jack stands to be of much use. And I feel safer with ramps than stands.
I can change the oil and (eventually) ATF and rear diff fluid without them. They are mostly needed for the front diff as well as enough leverage to break free rusted drain bolts (feel like I've used a quarter can of PB Blaster on my AT drain plug trying to get it loose...) right now.
