Anyone Use Quaker State Ultimate Durability For Over 10,000 Miles ?
New Jersey
Does anyone use Quaker State Ultimate Durability for more than 10,000 miles? I know it does not clean as well as others but i like it better than the pennzoil platinum because i think the PP is blended on the thin side.
Yes, I run my 2007 Mercury Milan with Quaker State Ultimate Durability. Run it for about 12,500 highway miles between oil changes. Internals that you can see (mostly timing chain) still look as clean as the day I got it.
Drain length is highly dependant on operating conditions and application. Most naturally aspirated 4 cylinders are typically very easy on oil while whereas direct injection or turbo engines or both can be harsher on the oil.
Originally Posted By: crazyoildude
I know it does not clean as well as others but...
Just to make sure there isn't any confusion. Quaker State Ultimate Durability does clean, and is good at it, it just doesn't advertise having the best cleaning abilities like some other oils might.
Overall Quaker State Ultimate Durability is an excellent oil and nobody should have any hesitations to use it. Now as for your question regarding using it for 10k miles, I'd say if other oils could do it, then Quaker State Ultimate Durability can do it too. However, I'd need to know more about your vehicle and its use before I'd feel confident saying any oil could go 10k miles in it.
Didn't the last PQIA VOA show Pennzoil Platinum and Quaker State Ultimate Durability as being the same in every (i.e: of what was measured) aspect?
exactly, i did PP for more than 10,000 miles, Quaker State Ultimate Durability should be same.
I got Quaker State Ultimate Durability in there right now. I'm dumping it at 3500.
I thought you went 3750mi on your changes??
Dumping at 3,500 lol Merk make sure you pick up some 10w30 Supertech next time. Lol, its much better quality!
I actually made it to 3776 last time.
Or straight Citgo
I'm seriously contemplating running it in my new Cruze. I've never had a vehicle new enough to warrant the use of synthetic, so I haven't used it personally. It's supposed to have an impressive add pack. I'd trust it for the above mentioned mileage.
Hey crazyoildude – We appreciate you choosing Quaker State for your engine! Rest assured that Quaker State Ultimate Durability Full Synthetic motor oil is formulated to meet the oil change intervals required by today’s engine OEMs which means it has great engine-cleaning capabilities. With that said, we always recommend that you follow the oil change interval recommended by your OEM since they designed, developed, and manufactured the engine. Hope this helps! - The Quaker State Team
An OCD self-medication on Quaker State Ultimate Durability
