Anyone use "Pro Blend" additives?
Tampa FL
I have a friend, an older guy who is a mechanical engineer that is also a car nut. He is very sceptical of "snake oil", but he swears by this stuff. He has a collection of 8 cars including classic GTO's x 4!!! Hemi 'cuda that he races, and a few other toys. Anyway, he put this oil additive into his race car, the cuda, and within 30 minutes of driving, he had to turn the idle down because it raised 300 rpms on its own. Now I find this hard to belive, but he absolutly swears by it, and has placed all there additives into his race car, and has gained 3 tenths!! If this [censored] really does "free up" the metal moving parts, that would be amazing. He has done a test where he put a regular bearing race into a pot of hot regular oil, and another race into into another pot with the same oil, same weight (Valvoline) with the additive. He brought them up to temp that a car would have inside the crankcase for 30 min. Then placed the races into a drill press with an arbor tip. The 1st race started to smoke and get damaged with around 30 ft lbs of pressure on the other hand the one with the additive took over 100 ft lbs of pressure on the drill press handle to start to damage the race. [censored]?! Tell me if this is even possible, and no, he doesn't work for the company that makes this stuff.
I call [censored] on the 3/10th's. No way that a 'race car' can pick up 3/10ths due to oil (or additives for that matter) in the 1320. Too many other variables that cannot be eliminated to substantiat this claim.
