| Thinking about getting a 5-year ceramic coating($1500~). Local detailer uses IGL Kenzo products. Never heard of it. I've heard of G-Tech Crystal serum. |
There's another detailer charging 1100 for a 5 year coating. I'm getting the PPF done by the same person I'll be getting the ceramic coating. So, I'll work something out. 1600 for both ppf and ceramic coating sounds fair imo.None of them are worth 4 figures, but if I had to choose one, it would be Opti-Coat Pro Plus for having the longest track record.
That sounds awfully cheap. Are they doing a partial front-end or a full front?There's another detailer charging 1100 for a 5 year coating. I'm getting the PPF done by the same person I'll be getting the ceramic coating. So, I'll work something out. 1600 for both ppf and ceramic coating sounds fair imo.
I'll look into full alsoFull hood and fenders or bust. The difference in texture and the line will be extremely annoying to look at.
Skip the snake oil and use your full original budget towards film.I'll look into full also
I think that's better. The cars Graphite Grey Metallic. You can hardly see the swirl marks.Skip the snake oil and use your full original budget towards film.
It already contains a top-coat. Certain coatings will streak pretty terribly when you try to install them onto top-coated films. You have to lightly polish the film before coating.You can put most ceramic coatings on Xpel film.
Are they doing a bulk install or using patterns plus extending edges?Found a guy that'll install PPF on the whole hood, bumper and door cups along with a 9 year ceramic coating for 2500
Patterns plus extended edgesAre they doing a bulk install or using patterns plus extending edges?
That is better than bulking it, but I hope the installer is experienced. It's real easy to leave cuts in the paint that will go unnoticed until the film requires replacement.Patterns plus extended edges
From his reviews and what another detailer said he does a pretty good job.That is better than bulking it, but I hope the installer is experienced. It's real easy to leave cuts in the paint that will go unnoticed until the film requires replacement.
19 540 w/29k milesIs this a used car?
Better hope the dealer hasn't done any major touch-ups or bumper refinishing prior to sale. Otherwise the paint may lift during the install process or when it comes time to replace the film.19 540 w/29k miles
I would maybe skip the PPF. Any chips will need touched up and when the film ages there will be a real chance of the paint lifting with it.19 540 w/29k miles
