Originally Posted By: kr_bitog
Originally Posted By: Audi Junkie
So, the 5w30 meets A5, or so it's claimed, off and on.
You aren't going to let that go are you? From their data sheets, it shows they have met it with the 5w30 and 10w30 formulas since 2006 at least!!! It's not an "on and off" thing, maybe you stumbled across an old bottle or something?
Quote:
That's inspiring. The old SL 0w30 did meet A5 but the SM "new one" does not, even though Mobil says it's the "same".
Old 0w30 (2003):
Quote:
Mobil 1 0w30 meets or exceeds the following industry specifications
ACEA A1,A5,B1,B5
API SL,SJ,EC,CF
ILSAC GF3
Ford WWS M2C913-A/B
General Motors GM 4718M
Typical Properties
Mobil 1 0W-30
SAE Grade 0W-30
Viscosity, ASTM D 445
cSt @ 40ºC 56
cSt @ 100ºC 10.3
Viscosity Index, ASTM D 2270 175
Sulfated Ash, wt%, ASTM D 874 1.2
HTHS Viscosity, mPa-s @ 150ºC, ASTM D 4683 2.99
Pour Point, ºC, ASTM D 97 -54
Flash Point, ºC, ASTM D 92 234
Density @ 15ºC kg/l, ASTM D 4052 0.851
"new" 0w30:
Quote:
Specifications and Approvals
Mobil 1 0w30 Advanced Fuel Economy meets or exceeds the following industry specifications
ACEA A1,B1
API SM,SL,SJ,EC,CF
ILSAC GF4
Ford WWS WSS -M2C929-A
General Motors GM 4718M,GM6094M
Chrysler MS 6395
Typical Properties
SAE Grade 0W-30
cSt @ 40ºC 63.1
cSt @ 100ºC 11.0
Phosphorous 0.08
Sulfated Ash, wt%, ASTM D 874 1.0
HTHS Viscosity, mPa•s @ 150ºC ASTM D 4683 2.99
Flash Point, ºC, ASTM D 92 228
Total Base Number (TBN) 8.5
MRV @ -40 º c 11,100
Density @15º C kg/l, ASTM D 4052 0.845
Draw what you want from that info.
Quote:
Wow, add the fact you need to spend extra for the EP line now, and the Mobil 1 customer really doesn't know what the heck they are getting.
Sure they do. Go look at the data sheets. Yes, it's ALL a conspiracy to cause you heartache and discontent, hence the reason you obsess upon it.... But you don't run it, so I fail to see the reason you are "out to get" Exxon-Mobil. I really doubt they care.
Quote:
The only time I saw Mobil 1 on Buy One Get One sale it was a typo from Pep Boys. Conidering I could get all the Pennzoil Platinum and Valvoline SynPower I want BOGO, as cheap as dino, Mobil 1 falls a bit flat.
Then don't buy it!!! Let the rest of us who don't feel Exxon-Mobil has some crazy conspiracy going on buy it instead.
It is simple, what you see on the website is different from what you see on the bottle label. It is true the A5 classification is on-and-off appears on bottle label. As far as I know ExxonMobil admits sometimes the formulations slighltly varies time to time on the ExxonMobil discretion. It does not make sense if they deliberately remove the text on the label if the oil meet the standard, and this I have been noticing from 2005 till today.
And conversely, it doesn't make sense for them to advertise that they DO in fact meet A5/B5 on their website if the product does not.
It is FAR easier for them to change the website content than the bottle labels.
