I am curious about the new 4-stroke weedeaters, and was wondering if any of you are using one. If so, how do you like it? Have you had any problems with it? Does it run OK when tilted? How heavy is it? Is it as powerful as a typical 2-stroke model?
A new two-stroke trimmer running Mobil 1 MX2T burns amazingly clean...quote:
Originally posted by Rick in PA:
I really like the 4-stroke because I don't have to breath the oil smoke while operating it and I don't smell like 2-stroke oil after using it.
Exactly. I consider small 4 cycle engines to be overcomplicated, low powered, and too heavy. IOW, an answer to a question I've never asked...quote:
I've used and maintained a lot of Honda engines over the years and I agree they are very high quality 4 cycle engines. I just don't find the added weight or complication of a 4 cycle to be an advantage in small power equipment.quote:
Originally posted by NThomas:
If you say the 4-stroke Honda is a joke or too complicated then you have never worked on one or used it compared to others!
I have a Husky 32cc trimmer, its 1lb ligher than the Honda!
If you complain about it throwing stuff at you then you trim the wrong direction!
Like I said, IF you buy a 4-stroke unit ONLY look at the Honda! 2-cycles are nice and should not smoke! Mine doesnt!
But people will grab the wrong gas can!!! Image you being sick and your wife thinking she will do something nice for you, she grabs the wrong can and trims for you! Your 2-cycle is dead!!
I couldn't agree more.quote:
For the umpteenth time. modern two cycles should not smoke. None of mine do and I run them at 32:1 or better.
