The transmission of my 2002 mitsubishi galant has been slipping between 2 -3 gear for about two months and it seems to get worst. I have to take my foot off the gas pedal to avoid the big jerk. I took it to 4 transmission shops and all of them recommended a transmission rebuild ($1600 - $1800). It seems like what they did is to use a scanner to scan the code, drive the car around and determined that the a rebuild is needed.
I already tired 3x drain and refill with Diamond ATF SP3 and added two bottles of Lubegard red. The problem is still there and there is no way I can change the filter since it is a lifetime filter inside the transmission.
I did lots of research and it seems like lots of things can lead to a transmission slip. Any suggestions what I can do next before spending $1800? Thank you in advance for the time reading this post.
