Group,
As part of my project to install Auto Meter gauges into my 300M, I am replacing my stock trans pan with one modified with a drain plug, and a temperature sender.
Even though I only have ~ 10k miles on the ATF+4 and filter in the transmission, I am going to replace the fluid & filter when I drop the pan. Do you guys have any possible recommendations for other ATF's other then ATF +4? I know this has recently been released to the aftermarket, but I want to see if there is a really good synthetic replacement.
Also, there has been some conjecture that ATF +4 is at least semi-synthetic, or fully synthetic. Can anyone shed some light on this??
TIA
TIA
