There is an a individual that's a member of a site I used to frequent that is an engineer at SWRI that does HDEO certifications tests (yup, those certifications you see on the back of a bottle of oil) for many of the big Diesel manufacturers...Anyway, he's also a motorcycle enthusiast and based on what he's seen in his years of testing his favorite conventional oil for bikes was DELO 400...But he said any of the name brand HDEOS are excellent for bikes...He used to post up some interesting charts from work on how they would measure ring wear as the engine ran by something called radioactive tracer technology...They could actually measure wear rates of rings, cams, cylinders ect ect as the engine ran...He would post up pictures of torn down engines for parts inspection after tests...Basically, they go MUCH deeper into their analysis than a used oil analysis...And another reason he likes HDEO's is that for an oil to pass diesel certifications every engine component that is affected by oil quality is measured for wear unlike the gasoline only certifications which all HDEO's carry as well...The HDEO tests are the most rigourous of any engine oil certification which is why he rated them so highly.
I'll leave with you one of his quotes...He's big on buying oil from the actual oil companies (Mobil, Chevron, Shell) instead of OEM branded oils (Honda GN4, Suzuki Performance 4, yamalube ect ect)..."OEM branded oils are low cost/low bid products they buy from oil company. They don't make, refine or blend oil trust me on that." And "Why would you buy a product that doesn't even have/source of the mfg's name on it ?" Good question, who actually makes those OEM branded oils ?
Just a little information for you folks considering HDEO's...And yes the source is reliable.
I've run Rotella for about 12,000 miles in my Bandit 1250 with 2,500 to 3,000 mile OCI's, now running Delvac and it runs smooth as a sewing machine with nearly 15,000 miles on it...However, since your BMW is air cooled a high quality synthetic might be a better choice if it tends to run hot since the shear resistance and HTHS is a bit better than conventionals of similar grade and that's a good thing to have when oil thins out with higher engine temps....
