Any Info on STP Filters?
quote:
Originally posted by acdcking:
Guys,
What is your take on STP filters? Any sites with info about them?
It's a Champion Lab's filter. If you do a search on here for Champion Labs, you should find a great deal of information.
Another source of info is here: Oil Filter Study
There is a guy on here that has worked for Champion Labs and he could probably provide you with loads of information.
Champion Lab's made filters (not ment to be a full list, just to give you an idea):
AC Delco
Valucraft
Bosch (USA Made)
Super Tech
STP
K&N Oil filters
Mobil1
I believe the STP to be in the same class as Super Tech and the like. A good filter all in all.
I think it is a mid pack filter. In common numbers, usually for the price, you can pick up an OEM, usually your best buy. If you find Wally's convenient, you can pick up an ST, or check the Valuecrafts, likely almost as good as the STP. It doesn't carry the bragging rights of a WIX or Mobil 1.
code:
Brand P/N Length width area, sq. in Fits endcaps mfg valves
Older data, 2000 ?
AC Delco PF9 102 2 1/2 255 77 LUV
STP S02856A 108 1 3/4 189 ''
Purolator L10193 105 1 3/4 184 ''
Power Flo SL 14619 76 2 3/8 180 ''
Hastings LF143 71 2 1/2 178 ''
ST ST3950 98 1 3/4 171 ''
Fram PH 3950 48 1 3/4 84 ''
2003 filters
Miata B6Y214302 69 1 3/4 121 1991 Roadster
AC Delco PF2244G* 46 3 138 02 Caviler France
STP 9018 57 21/2 143 '' Korea
Purolator L15436 52 21/2 130 '' Thailand
WIX 57082
22 Aug 03 filters were a year or 2 old
ST ST3950 84 1.75 147 77 LUV metal ADBV, bypass,
Purolator L10193** 76 2 152 '' card USA '' , ''
Purolator L10193 96 2 192 *** '' metal India '' far end
AC PF1177 92 2.5 230 '' card Canada ''
AC PF 47 56 2 112 92GrandAm metal ''
AC PF 52 53 3.75 198 '' OS '' ''
ST ST 3387A 46 2 92 '' '' USA ''
ST**** ST3950 90 2.1 189 77 LUV Metal ADBV, bypass
*The AC, Hastings, and Fram all said PURFLUX L264A on the end of the plastic housing.
**Interesting 1 piece of rubber for both valves
***The media was noticable thinner than the others
****9-04 newer black case
Older data, 2000 ?
2003 filters
WIX 57082
Code:
    [/SIZE][/FONT]
[HR][/HR]
[/QUOTE]
