Any info on a PH 253??
flint,mich
Hello, installed a derale remote trans cooler and the replacement filter listed by derale is a 13092. The picture of the filter on the site has the numbers PH253 printed on it. after some research I have gathered that the filter Ph253 is Manufactured by Champ, and is a cross for a AC PF-13 or a fram ph-43. Can anyone shed any light on this for me? The derale filter sells for 17.00 but if they are indeed a direct cross for a AC PF-13 I can pick them up for about 4.00 at wally! Thanks for any help, Mike
Yeah ..pick up a SuperTech or MC Ford/Chrysler filter for $3-$4 ..or go as expensive as you please. If you go expensive, just leave it on long enough to make it pay for itself.
All of the below will work with your Derale kit.
Manufacturer Part Number
AC HD222
AC PF2
AC PF2149
AC PF2217
AC PF41010
AC PFAFL1A
AC PFL1A
AC PFW1120
AC X61
CHAMPION LAB. HP1
CHAMPION LAB. PH2815
CHAMPION LAB. PH8A
DERALE 13092
FRAM HP1
FRAM P8427
FRAM PH2815
FRAM PH2879
FRAM PH3381
FRAM PH3569
FRAM PH4854
FRAM PH7650
FRAM PH8A
K&N HP-3001
K&N PS-3001
MOBIL1 M1301
MOTORCRAFT AFL1
MOTORCRAFT FL1A
MOTORCRAFT FL1HP
MOTORCRAFT FL281
ONAN 122P193
PURO L30001
PURO L30119
PURO L30257
PURO L30341
PURO L37673
PURO L38257
PURO L39001
PURO L40316
ROYAL PURPLE 308A
WIX 41515
WIX 51515
WIX 51525
WIX 51545
WIX 51622
WIX 51775
Are there actually any difference between a regular oil filter and a supposedly spin on transmission filter for this adapter?
I guess what I'm asking is there a different design for the transmission filter? Compared to a regular old filter?
The Baldwin high performance microglass media FL1A equivalent, the B2-HPG, makes a GREAT ATF filter, I got mine from Zoro. The Ultra XG8A would be a good choice too.
A hydraulic filter is what I'd be using. Donaldson P551327 or Fleetguard HF6351 would do a much better job than any automotive oil filter.
