Any Horror Multi-Vehicle ATF Stories?
Florida
Been searching on the internet for ATF stories on how MV ATF fluid ruined a transmission - Castrol Multi-Import is bad - Maxlife ruined my transmission - etc... Probably 15 different ways to construct that sentence it but can't seem to find hits. I'm not referring to wrong applications such as putting ATF4 in a GM truck or Honda DW1 in a Toyota, but using a multi-vehicle ATF that someone used for the correct application, and the trans still went bad specifically due to the fluid. Are ATF fluids that interchangeable? Been using Castrol IMV in my 03 Toyota Matrix for 25k miles and it seems to be doing pretty well. 2019 Sorento I will still use SP-IV.
Personally, I have had success using multi-vehicle ATF's as long as it is not a Honda.
For example, I did a 3x drain and refill with Amsoil ATF in the fiancee's 07 Accord about 2 years ago. Initially, the shifts were a bit more "crisp" but were very acceptable. After about 20K, the shifts became extremely harsh and sloppy - especially the 1-2 shift. The Amsoil fluid was still bright red.
So, I performed two drain and refills using Honda DW-1 spaced 100 miles apart and the shift quality has been mostly restored to normal.
On the other hand, we have used hundreds of gallons of Maxlife ATF and Kendall VersaTrans LV in place of Nissan Matic-S with zero issues.
I'm thinking you might need a metric to measure by. I mean, let's say someone put in Maxlife into a transmission, changed it every 30k from new, and the transmission broke a hard part (gear, sun shell, whatever) at the 250k mark. Fluid fault? What if instead the clutches were toast at that 250k mark instead? How do you determine normal wear and tear from effects of wrong fluid?
I suspect that wrong fluid usage will have immediate consequences due to different friction modifiers causing shift quality to change. But I don't know if it would translate into short trans life... a softer shift should wear things faster, but if it takes 200k to wear something out... was that normal wear and tear?
I'm not sure about wrong fluid being able to be used for say 100k but causing rapid wear-out of the transmission. They are all oils with similar properties and purpose. Short of CVT oil they all have to deal with the same bits. It makes me think that it would be a long time for wrong oil to do anything, like well past 100k. Shift quality aside that is, and wrong fluid aside (ATF4+ vs Type F as you mention).
I too have had success with MV fluid, specifically Valvoline MaxLife Multi-Vehicle. I'm currently using in five vehicles including my son-in-law's 2012 Ford Fusion. it appears to work well.
A user on here had a GM transmission fail after switching to Valvoline Maxlife. I admit the timing was a bit unfortunate and he even sent a sample to Valvoline; he continued to badmouth the product even tho 100s of people have used it with no issues.
The apparent unvocalised premise of his position was "a properly maintained transmission will never fail" which is a bit tenuous.
I use Maxlife in my friends Tundra which calls for Dex3.
There were a lot of other things about his position that were more than a bit tenuous, his claim of failure wasn't the only thing. He had zero proof it was the fluid that caused the failure (assuming it even happened in the first place).
Probably this long thread and the individual in it that got banned:
https://www.bobistheoilguy.com/foru...-caution-regarding-valvoline-maxlife-atf
I've been following this stuff since about 2001 and never have I heard of maintenance enthusiast BITOGer type using a suitable for use ATF, and having their AT fail because of it.
I have used it in Honda, Hyundai, Toyota, Nissan, Isuzu and domestic products without issue.
How many trans missions fail because of the lube used? No I am not saying lube never changed or a high mile wear out . Parts breakage is why the trans failsand no oil will prevent a parts failure.
I have used it mostly in older Hondas, Toyotas and Nissans with great results; certainly never a failure.
Recently I switched to Idemitsu specific blends in the newer cars, just because.
I will continue to use MaxLife in the older vehicles.
I think the best you'll find is some qualitative data points such as the transmission shifted smoother with OEM fluid vs MV.
I've had luck with MaxLife in Nissans but I didn't like the feel in Toyotas that need T-IV. I've also used it in a Subaru that called for both ATF-HP and DexIII with success as well.
Never had an issue myself. Only horror stories I have heard is using regular fluid in CVTs or other places its just not called for at all.
Uses a lot of Castrol Syn LV, Maxlife, etc... in many vehicles with not issues.
For years and on many different vehicles I have been using the Valvoline MaxLife with great success. Have used it in everything from Kia to medium duty diesel trucks. Often it improves the transmission shifting and down shifting. The only time I have not used it is on my daughters Honda Accord. I use the Honda supplied $tuff. And I have used Castrol CVT fluid in the Nissan Rogue.
2006 Acura TSX, auto, 250K miles (best car I have ever owned)
Up until 100K, only OEM fluids, after that, a collection of Castrol Multi, Valvoline Maxlife, Valvoline Import, Idemitsu, with the occasional OEM, every 6-10K drain and fill.
Car is running like a top, with the exception of the AC. Usually these compressors go out WAY before 200K, so I'm lucky. New one and condenser going in this weekend.
Oh man was that thread a lot of fun.
I have used a castrol imv in a hyundai sp3, mercon and mercon v applications with success. I have used atf +4 (not multi vehicle but still) in an sp3 application with success and i have used maxlife in mercon, mercon v and toyota ws with success. Initially i thought maxlife wasnt good in my a4ld but later learned it was a small leak causing fluid level to drop.
All in all i use it depending on the factory fluid. For fluids like atf+4 and dw-1 id recommend sticking oem. But with things like dexron 6 and mercon lv where most fluids are designed around them multi vehicles are totally fine by me. I get that what i have stated for experience with somewhat goes against my advice but hey, I wanted to experiment. For the sp-IV, it is a high quality factory fluid and worth sticking to for peace of mind imo.
https://bobistheoilguy.com/forums/ubbthreads.php/topics/2879800/1
This was the thread i had in mind when i was referring to one as fun and the closest thing i know of to what you're looking for.
Been running Maxlife for 2.5 years in my daughter's '10 Toyota Yaris and many years in my brother in law's '04 Sienna. Zero issues with either. I'm guessing ML will probably end up in my Tacoma as well
Just put Maxlife multi vehicle in my 2002 Tacoma with 217k miles. It's now shifting extremely smoothly, unlike before. It was also about a quart low beforehand. Shame on me for not staying on top of it.
I'll do a second and third drain and refill in the coming weeks with more Maxlife.
My 05 Silverado work truck got flushed with QMI multi vehicle synthetic ATF. I first did a pan drop at home with Castrol dexron 6 and a new filter, but it needed cooler lines repaired so I drove it a couple weeks after the pan drop and then took it to the Goodyear garage I used to work at, to have the lines repaired and rest of the fluid flushed. I forgot they used the multi vehicle stuff or I would have requested dexron 6.
Either way it shifts as good or better than it did with the original 190k mile fluid. I know we never had any issues using the multi vehicle stuff on customers vehicles, I just would prefer dexron 6 in it because I'm fussy. I'll probably just leave it for 30k and then do a flush only with dexron 6.
Forgot I also have Valvoline maxlife in my 270k mile gm 2004R in the Cutlass. It shifts great, seems like it will just keep going forever. I'm pretty sure it has a shift kit in it, so shifts are very firm. Since 110k when I got it I used mercon 5, then dexron 6, flushed every 30k or less.
Odds are that people who do use MV fluids in their cars also change it much, much more frequently than the average person. I think every mechanic that works on transmissions will say that fresh fluid is the most important factor (after "right" fluid, i.e. not putting CVT fluid in a non-CVT or vis-versa or ATF+4 in a trans that doesn't use that type).
