Any harm in...
MACON, GA.
Is there any harm done in mixing one qt of Mobil 1 5W20 and six qts of the MC 5w20 in my 2005 Ford F150. 5.4 L engine. The engine has a seven qt capacity . I am just wondering if there is any benefit to this or am I doing something that I should not?
Neither harm nor good - you still have MC basically and it tests ok in your truck.
I wouldn't spend an extra $3 for this but it's ok if you had a qt around to use up.
quote:
Originally posted by GoldenRod:
Motorcraft by itself is a way better lubricant.
You really hate M1 don't you...
What is the purpose behind your plan? Do you want to achieve something with it? Or just use up a spare quart of M1 sitting around?
The biggest caveat that I see is the warranty on the truck. On the off chance you do have an oil related failure I can imagine the problems your brew might cause when you try to get it covered under warranty.
The warranty says use 5-20. He's adding 5-20.
Its all SM. No warranty tells you what brand of oil to use just viscosity and API rating.
