Originally Posted By: donnyj08
Originally Posted By: 90crvtec
I've long since sold my S2000 and I've been out of s2ki.com for a while now. However, when I left off years ago there was still a large amount of debate over which filter was best.
The bottom line is, a lot of guys like to run an aftermarket filter and the only thing I ever heard them say was "I do it, and I don't have problems." If you're like me, that kind of anecdotal reassurance is worth exactly what you paid for it.
The S2000 is one of the only modern engines produced by Honda that still specs an oil filter separate from the rest of the Honda fleet. I believe there is a reason for this, and just comparing the filters side by side makes it pretty obvious to me. The PCX 004 is a very stout filter, the filter medium is of high quality and the walls of the filter are very thick.
The oil pressures and flow potential of an oil pump designed to not cavitate at 9000RPM are a somewhat unique requirement on a modern mass produced car. I truly believe this is why Honda continues to spec a different filter for the S2000.
Could you run any number of aftermarket filters on your car and never encounter an issue? I'm sure that you could. But when you can buy an over built, quality, OEM produced filter online for the same cost as a K&N or Mobil 1 one-size-fits all filter....I would choose the OEM solution every time.
I usually ordered the filters by the case online, along with some other OEM stuff to help offset shipping. While you're at it, order some of the copper crush washers for the differential drain/fill plugs as well. You'll need em.
Hope you enjoy the car. Mine was a 2003 and I absolutely loved it. It was one of the easiest cars to maintain that I have ever owned. It was also one of the most reliable.
Mine is a 2004. So far I'm enjoying it. The build quality seems excellent and at 69k miles it seems very tight. I plan to use the PCX filter, I was just curious if any s2000 owners knew of a good aftermarket filter that meets the spec. The previous owner who put 56 of the 69k miles on it used Mobil 1 Extended Performance 10w30 and an OCOD every 7k miles. The car runs very smooth and quiet and looks immaculate looking through the fill hole.
I did order extra washers for the transmission and differential. I just changed the diff with synpower 75w90 and the transmission with Honda MTF. I plan to just change both every 10k miles or so since its easy to do and cost less than 30$ to change both.
I also replaced the air filter and cabin air filter both with genuine Honda filters.
I've owned my 2006 S2000 since it was new and it currently has 10,000 miles on it.
I've changed the oil yearly using the green coloured German Castrol 0w30 and the OEM Honda S2000 filter made by Toyo-Riki and would contine to use these filters if they were still availble (not the case anymore). My recent filter of choice for this car are the Mobil 1 filters which Mobil claims as being good for 15,000 miles of use.
I've changed the transmission fluid using Honda's excellent motor oil like OEM fluid at 5,000 miles and will change it again at 10,000 miles this spring. I plan to change the differential's fluid at 15,000 miles or next year which ever comes first.
As to Mobil 1 oil: my M5 and this oil did not like each other (engine was quite noisy)so I avoid Mobil 1 in motor oil.
