Then why was the yellow
Originally Posted By: UG_Passat
Originally Posted By: getnpsi
I got some yellow stain glass paint and hit my plastic fogs 4 years ago and they still look decent. Remember fogs aren't for you to see better it's so others know you are coming.
properly designed, there are for you to see..,, in the fog... the fogs should be lighting up the lower sides of the road, so you know where the edges & lanes are.
French yellow... that's a different story
PROPER foglights have a pattern designed to light the road directly in front and to each side but not the FOG above. A yellow color for the light may or may not reduce the amount of reflected glare from fog, snow, and rain. (The French think so) (The yellow is actually what's left after the glare producing BLUE has been filtered OUT) The only benefit I can see is that most US drivers will understand that the yellow lights are FOG lights, and that you are NOT some jackwagon with his/her highbeams on.
Fog lights have evolved since... there is less focus on lighting up the road in front, more focus on lighting the sides.
French Yellow was NOT designed for fog lights in mind. It was for the French to easily differentiate French registered vehicles from other countries. The French stopped doing it, as the paint was carcinogenic.
In some forms of racing, yellow lighting is used to differentiate certain classes.
Unfortuntately, the new riceboy trend is driving with HID low beams and yellow high beams during the day time.
why, then, was the yellow used on "optional" lighting units such as fog lights. The science of filtering blue is quite well established. The yellow tint used to absorb blue is often IN the glass, not "paint".
