AutoMechanic
Site Donor 2024
I don’t drive with it open like that. I only see it at the local fair here when the cops direct traffic they have them propped open like that.
Excellent post! Agree 100%. Truth is, it’s metal, not human. It benefits the engine to stay warm as long as possible to prevent cold starts and having to reach operating temperature. Well said!Basically. IMO, you're reducing wear on the engine by keeping it closer to the operating temperature if you restart it, you're saving yourself time and hassle, and you're saving wear on the hood latch. There is no harm in letting the engine sit there, at or near its operating temperature. If it needed to cool off faster after shutdown, engineers would have designed it that way. At the end of the day, it's not a human or an animal, it doesn't "feel hot", it's a machine that was designed to operate a certain way.
But, I can understand doing it, if it "makes you happy"; there are lots of inexplicable things I do that "make me happy", haha.
Police in Havasu used to drive with the hood open held by the safety release. Cars had it rough there in the 80's. I switched the Seville's fan clutch to straight fan, a popular and effective mod at the time.I don’t drive with it open like that. I only see it at the local fair here when the cops direct traffic they have them propped open like that.
Yes I’m sure back then it probably was rough. I’m not too familiar with that area but it sounds like a hot place lol.Police in Havasu used to drive with the hood open held by the safety release. Cars had it rough there in the 80's. I switched the Seville's fan clutch to straight fan, a popular and effective mod at the time.
Yes, especially older models where the plastic is brittle.the rubber/plastic parts are the ones taking it on the chin with a hot engine compartment.
Key word here is towing. I have been towing 8000lbs regularly for 10 years with two different gas trucks and after pulling some of the larger passes out here 4000 to 8000 feet it is hot, really hot under the hood. I have not experienced any problems, but it does wear out the plastic and rubber components faster. When towing like that the exhaust manifolds are HOT. I remember seeing my old 89 GMC 1 tons manifolds glow after pulling over the Continental Divide on I-90. The 02 and 17 don't have the problem as they are not working near as hard as the old TBI 454.LOL, sorry, but I found the comment about a "hard" 70 mph run. I don't consider 70 mph driving to be very strenuous for modern vehicles.
Perhaps after a 110 mph dash from Kingman, AZ to Las Vegas on Route 93, in 100 degree heat with the A/C on full blast...then maybe I could see opening the hood. Except I didn't, I parked the car in a parking garage with the hood closed; still works fine.
Everyone is bored...13 years necro...
exactly, the rubber plastic and wires.Are we talking about the engine or the rubber/plastic components under the hood? The engine is fine with the heat, the rubber/plastic parts are the ones taking it on the chin with a hot engine compartment.
At the drap strip is also a good place to open your hood between runs especially if you have an intercooler sitting on top of your engine, but who designs engines like that?
Unless you can drive with the hood open, I don't see much point opening the hood "after" you parked in your garage. The engine, at that point is as hot as it's going to get. If there is damage, it's done. Shortening the time it stays that hot will do little if anything to prolong the life of your car.Heat management is a huge issue for me here in FL, so yes, I open the hood almost after every trip, once the car is in the garage. The garage door is also left open, and then I might run a fan or two. One generally blows into the radiator, to help cool the engine compartment, and the other directs the air flow out the door.
I do this in order to keep the house a bit cooler, as well as reducing heat load on plastic and rubber parts on my car. GM used to have some pretty bad firewall mounted plastic fan housings and impellers that would get very brittle from heat. Not easy to change. Even the new C8 Corvette was given special heat flow routes under the hood to keep things like engine mounts and hoses cool.
So yeah, it's a thing.
There is also such a thing as "heat soak" so no. Besides, I said it was as much to reduce the garage temp as it is the engine temp.Unless you can drive with the hood open, I don't see much point opening the hood "after" you parked in your garage. The engine, at that point is as hot as it's going to get. If there is damage, it's done. Shortening the time it stays that hot will do little if anything to prolong the life of your car.
