Any advice to bang out this trunk lid dent?
Maryland, USA
Some jerk backed into my daily beater with a rolloff or tow truck or something. I'm not looking for perfect, I just want to bang it back out so it looks normal-ish. The problem is that the thin inner layer of metal that the wiring clips onto is in the way. Since I probably need to wail on it with a hammer to undo that crease, what tool would be best to cut out a section of that inner portion so that it doesn't cover the dent from the outer portion of the trunk?
I'd take it to a paint-less dent removal guy and tell him to do his best. It won't be perfect but it should be pretty good.
When my Honda was almost new a deer ran into the driver's side and dented pretty much every panel. The paint-less dent removal guy didn't want to touch it because it wouldn't be good enough on a new car. Not the same problem for a beater. He charged me $50 to remove a row of deep door ding dents on the passenger door - and it's perfect!
That’s a pretty sharp dent and a hammer isn’t going to make it look “good”. Maybe if you can pull some of it from the outside but it’s so sharp you aren’t fixing it yourself with any real success.
Junkyard decklid if you can’t stand it.
Hammers and 2x4s will stretch the metal and knock paint off on the crease and look awful.
I'd see about getting a deflated football in the gap between the sheet metal and the frame behind it. Maybe the Patriots have some left over. :LOL:
Then, naturally, inflate it and watch that dent gently work itself out.
I had considered this, but I figured it would just wind up jacking up the sheet metal before it ever popped that dent out. Worth a try I guess.
