JHZR2
Staff member
I’ve asked about the old B&S naming convention and lengths, but I’m a bit more confused about the heat range.
For reference, the recommendation is here:
First, the Champion J19LM has superceded the CJ8 series. So a heat range 19, about the hottest champion makes, in place of an 8. While I get it that they may have had to do some things to deal with emissions, is this really prudent for “antique” (mid-late 80s flathead engines?
Now, cross references. Take the listed Autolite 295. It cross references to an NGK B4, while the CJ8 cross references to the NGK B6S. At the same time, the newer J19LM parts cross reference to an NGK B2 plug. NGK is hotter as the number goes lower, while champion gets hotter as the number goes higher.
It seems that maybe the NGK B4 or the Autolite 295 are good compromises on heat range for these older engines. Or are we just better off running higher heat range plugs and changing yearly?
It seems somewhat overly complex and arbitrary.
I’ve seen some comments to run the coldest that doesn’t foul. But at the same time I’ve also read to burn hotter to help reduce emissions.
So what’s the best bet for older engines running modern fuel?
Autolite cross reference:
And the Champions:
And the Champions:
